Very good first CU change
@Raptor0014 !
Also very brave to put it online as every minor detail will be examined and criticised, still I guess that is what you want for learning purposes.
@westward does have a good point about the 6mm in conduit though, on a 40A breaker. I'm never too sure which reference method takes preference though when only a very short run is in the more strict reference method.
I will add reg 521.5.1 . I believe the main earth should enter through the same hole into the CU as the line and neutral tails, to negate possible electromagnetic effects. I stand to be corrected though.
