bet it's going to have halogen fire bulbs in it.
Nope, Tel...led GU10s, 100° beam angle, 5.5W...I've not had that wide beam angle before, just the usual 36 or 38° so I'm interested to see how they perform.
Plausible deniability or not, I've never been in there before, so it wisnae me, m'lud!
here's a pic of the new fitting, and it's not bad, considering how awful some of them are.
usual cpc to "tag" on base, into block and with a fly lead to the mounting bracket as well, taken from a bolt holding one of the lampholders. It's also a decent diameter, allowing a fair degree of positioning over the original rose position. TBH, not bad really.
Yep - seen a lot worse - with smaller 'roses' that style of terminal blocks is often unusable, since the existing cable is too short to reach far enough away from the ceiling to connect to the terminals with a screwdriver.... So you end up adding tails and not enough space in the rose for existing cables, so end up hacking the ceiling out to fit a wago lite or similar in there...grrr
Wish these light fittings would switch over to quick fit terminals, cost would likely be pennies these days if that.
Meanwhile...
COVID, people.
I had my first at 11 this morning... didn’t feel a thing. Took the afternoon off and watched telly.
9:30 pm tonight.... got the shivers. Legs are jelly... ache in between my shoulder blades.
I know side effects are normal up to 24 hours later....
Did anyone else get knocked down with the first jab?
(that’s not a boxing pun)
COVID, people.
Me. Very similar. Lasted 24 hours then I was fine.
You'll be pleased to know that based on people I know it seems to be the second jab that knocks more people out (mine is booked for June). Only seems lasts 24-36 hours though...
2nd jab last Saturday. Didn't even feel the needle for the first one, and no after effects whatsoever. Felt the second needle a little, but again, absolutely nothing afterwards. Can't even determine exactly where the needle went in.
Would be interesting to compare if the jabs you had where the Astra Zenica or Pfizer, I had the Pfizer jab and the first gave me an achy arm the day after, the second jab no problem on the day, but very wobbly the day after, it does seem the Astra jab is not as intrusive with side effects.
I was stabbed with the Astra felt rough from about 12 hours later to 30 hours.
mine was on a Friday so I managed to milk it for sympathy all weekend though.
I've had the first jab and just had an achy arm the day after. Could barely feel the needle. This was the Moderna one.
i had the Astra. jabs 2nd one 10 days ago. no side effects from either. ( apart from the 6 fingers on myleft hand ).
Better and easier to play a twelve string guitar with as long as you are left handed otherwise they will get in the way up the fret board, so take up the piano.
i can't even play a 4 string guitar. my musical abilities on a 1 - 10 scale rank -10. music teacher at school (many moons ago) said I'd never have any musical talent as long as I had hole in my arse. (but I can fart a passable version of Smoke on the Water).
My surgery phoned me up today to make an appointment for my 2nd jab. I couldn't do it this week (I'm in Nottinghamshire, surgery in S.Wales) so I'm booked in for Thursday next week. I'm on the Astra one. I wonder if the micro chip has a digital readout like my old Astra GTE had ?
My mate had a red GTE. I remember two things about it, 1. it always had electrical problems and 2. that digital display! It was like Knight Rider - very advanced for the time.
Mine was red, apart from the spoiler which had faded to Vauxhall pink. I liked the dash. A real talking point with the girls at the time :-) I remember seeing 127mph on it once. Ah, those were the says. Only problem was when one of the lamps went behind the display and you couldn't see a thing.
I’ve had both jabs (Pfizer) a while back (work in care home). Don’t know of any of the staff have had a reaction, some had the Oxford one.
The only reaction, is the skill or lack of it of the person administering the injection itself. First one didn’t feel a thing, second one, I think he thought he was playing darts!
What about the other posh one, the Kitten. People always forget that one.
Space Station sightings tonight for the SE: Time: Sun May 16 10:50 PM, Visible: 7 min, Max Height: 79°, Appears: 10° above SW, Disappears: 10° above ENE
Tonights Space Station sighting for the SE: Time: Mon May 17 10:03 PM, Visible: 7 min, Max Height: 50°, Appears: 10° above SW, Disappears: 10° above ENE
Grab your sparkly outfits, pour yourself a fruity cocktail and get those singing voices into practice.......
Tonight on BBC4 at 8pm is the first part of this years Eurovision Song Contest, with the second part on Thursday and the final on Saturday night.
Many of last years cancelled contestants are returning, albeit with different songs, so they’ve had time to practice. And not all will be performing live in Rotterdam- backup recorded performances have already been filmed in case of COVID infections.
Love it or hate it, it’s one of those annual events that doesn’t get involved with too much politics.... yes, the scoring can be a little biased, and you can never understand how the top 5 or so can be so far ahead of everyone else..... or you question why Australia can be in it....
Never mind the questions..... just enjoy the show!
i'd rather be installing a sewage pump.
HappyHippyDad
Supporter
Gloucestershire
Coronavirus - Keeping it light :-)
Electrician Talk Forum
HappyHippyDad,
littlespark,
