- May 30, 2025
- 7
- 0
- 31
- If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at?
- United Kingdom
- What type of forum member are you?
- DIY or Homeowner (Perhaps seeking pro advice, or an electrician)
After decoration needed to change light switch as it had stopped working. Heating engineer changed it over for us! But since it was changed over all of the lights out side and in on the ground floor work by having to have this one switch on! There is another light switch in the same room, can turn on and off from either. This one has not been touched just the one in the pictures. We stay semi rural and trying to get an electrician to come for one light switch is proving to be difficult. I have attached pictures if someone could advise where the wires are supposed to be I would very much appreciate it.
Thanks in advance for any help/advice given
Paul
Paul
