“Any chance of a quick look at our cctv while you are here, one of the cameras isn’t working”
First time I’ve seen a cable run inside
a soil stack.
Now that is using your initiative. ?
Reactions: timhoward and DPG
About five years ago I suggested a rewire as much of the wiring is 50+ years old. Whoever replaced the board have actually made it worse.
Disgrace. How can such people masquerade as electricians?
Damage to the new board, too...carried through with the drill? and that cb, as well?
Was it not a level surface to begin with?
Levitation... or have the two outside conduits grown wings?
Can't quite picture the original board but I can't understand why the conduits don't line up because they cannot be moved.
Reactions: ipf and timhoward
Could there have been a thread converter on the end of one conduit to suit pre existing holes in the original consumer unit?
I remember when I started off in industry I used to see a lot of issues with bushings where the conduit is used as CPC
They'd be sparking sometimes when check EFLI at outlets
50 years in the trade and I've rarely come across anything like that. Since the Millennium, I can see it being much more of an issue. Hence westwood's photos.
Domestic standards aren't just creeping into industry, for sure.
Something being the neutral block of a MEM Exel? Hopefully it didn't let go completely with a 3-phase load on.
Indeedy but no I don't believe the neutral was lost. Found it by chance just been back to change but must have been hot, new one fitted now.
Indeedy but no I don't believe the neutral was lost. Found it by chance just been back to change but must have been hot, new one fitted now.View attachment 88504
At least you have not chewed the screw heads up on the new one like someone did with the original.
In 40 odd years I have never replaced one of those and found that on eBay £12.99 and still in its original packaging.
The screws are so thin compared to how large the cable entry holes are on that MEM stuff!
Reactions: ipf
The screws in the new block are considerably bigger than the old one which has probably been there since the 60s.
Never thought I would be saying it but I agree, they do look narrow.
Although. these days, there'll probably be more dummies trying to connect 2.5's in them.
  • Funny
Reactions: timhoward and ferg
who you gonna call? Sh!tBusters.
8K
Darkwood,
mainline,
