Doesn't even make sense. And you are just avoiding the questions asked.
Will you suggest another solution.
A 15A round pin is suitable, but it us the shark makers warrantees that is the problem.
Read back on the thread.
Do you do this sort of thing on other forums as well? I wouldn't mind, but you do seem to have a modicum of electrical knowledge and maybe you could offer something useful?
I always use solid links in my old table lamps which have that nice single insulated twisted flex, 3 amp fuses are rubbish and need replacing far too often when my old stock Chinese 150w bulbs blow, they only last a couple of weeks usually so I reckon I've saved £££s in fuses.
You trolling again Dave?
i can help you to save a fortune.
I will sell you as many as you like for your own personal use.
£12.50 each with a minimum order quantity of 100.
lead time 14 days.
I think I might be on a winner here!!
Why bother trying to get solid fuse links XD
A 15A round pin is suitale but it us the shark makers warrantees that is the problem
The most obvious solution that sprang to my apprentice's mind has since been suggested in post #36 - you have a fused spur above, so stick a flex outlet below.
This ain't rocket science and you're seriously overthinking a problem that's very unlikely to occur. How many such 'inaccessible' fuses have you had to replace and what caused those fuses to blow?
Why would you ever need to access such a fuse? if it has blown the appliance is faulty and will need to be pulled out to repair it anyway, at which point the fuse becomes accessible...
Having inaccessible fuses is a no, no. Obvious.
Have fuses accessible like in say an FCU, which is also an isolator as as well.
The thread is about two points:
1)
Where to buy solid links for 13A plugs?
2)
Manufacturers not honouring warrantees because a moulded plug is cut off to hard wire the appliance or fit a round pin fuseless 15A plug.
John-SJW,
westward10,
