Shocking! Surely they know to use grey for neutral and black for earth, if using a cable with 3Ph colours.
A banjo short of deliverance?Not dangerous, but a classic example of someone who's seen other installs and copied them without understanding why...
And correctly stripped length!Oh, for a bit of green sleeving!
It is not Flexishield as its CPC is stranded.Is the outgoing white cable FP200?
Hi-Tuff I believe - though forget the official designation. Has a flexible metal sheath that is connected to CPC along it's length, so can be used in place of armoured in some circumstances (though it was only a short feed to another socket in this case).Oh, for a bit of green sleeving!
Yes I think you're right that it's not Hi-Tuff. There was some left over from an a/c install on site which I was asked to use. I checked it on a previous visit for suitability and can't find the note I made immediately, but I have a feeling it was BS8436, which is low Emission cable with similar properties to FP (which is BS7846 I believe). (Both listed in 522.6.204 as suitable for burial <50mm though it wasn't used for that in this case).HiTuff (NYYJ) doesn't have a metallic sheath, it has an insulated CPC... at least all the HiTuff I've ever bought has. If the insulation on the live conductors is silicone rubber (it looks like it might be), it's an FP series cable unless I'm much mistaken.
One step up from under the plinth!
I have seen plenty just thrown under the plinth , even in £1,000,000 new builds I find surface boxes just slung under the kitchen plinth for the fitters to plug in toOne step up from under the plinth!
Not anymore it isn’t.I assume the inspection year date was 2004 in which case it's outside the recommended inspection period by any stroke of the imagination.![]()
