40 years it’s been wired like this 👇 apparently….nice brass light fixture as well 😳
Looks like a high ceiling.
Maybe they’ve taking “placing out of reach” a valid means of not getting shock over earthing it.
Reactions: Dartlec and Baddegg
Not dangerous, but a classic example of someone who's seen other installs and copied them without understanding why...
Or maybe he knows something about the conductivity of plastic....
(The armour was earthed at the source end)
A banjo short of deliverance?
Oh, for a bit of green sleeving!
Is the outgoing white cable FP200?
Reactions: pc1966
Reactions: freddo
Hi-Tuff I believe - though forget the official designation. Has a flexible metal sheath that is connected to CPC along it's length, so can be used in place of armoured in some circumstances (though it was only a short feed to another socket in this case).
HiTuff (NYYJ) doesn't have a metallic sheath, it has an insulated CPC... at least all the HiTuff I've ever bought has. If the insulation on the live conductors is silicone rubber (it looks like it might be), it's an FP series cable unless I'm much mistaken.
Awesome placement of the cooker isolator by the kitchen fitter.
Yes I think you're right that it's not Hi-Tuff. There was some left over from an a/c install on site which I was asked to use. I checked it on a previous visit for suitability and can't find the note I made immediately, but I have a feeling it was BS8436, which is low Emission cable with similar properties to FP (which is BS7846 I believe). (Both listed in 522.6.204 as suitable for burial <50mm though it wasn't used for that in this case).
Reactions: SparkyChick
Reactions: Raptor0014
100 years between inspections seems a touch high to me. :)
Just phone the number shown and ask them to clarify.
I assume the inspection year date was 2004 in which case it's outside the recommended inspection period by any stroke of the imagination. 🤔
Not anymore it isn’t. 😉
8K
Darkwood,
mainline,
