Guest viewing is limited
If you were wiring 8 gangs of 2 way light switches. Would you wire 8 independent circuits, so 8 no. 3 core between switches. Or would you run a live, and loop all the L1's together, then just run 8 no. 2 core between switches ?
There are a few ways to do this and your wiring system may dictate how you do it. For T&E I have 'three plated' to the switches to save on the amount of wiring at the switch. For singles I would take a line through the switches, are these all on one circuit.
There are a few ways to do this and your wiring system may dictate how you do it. For T&E I have 'three plated' to the switches to save on the amount of wiring at the switch. For singles I would look a line through the switches, are these all on one circuit.
It's all on same circuit.
I don't understand 'three plated' and 'Look a line through the switches' ?
I edited 'look'.
Three plate is where you take a line around your lights then a two core to the switch, just imagine your switches are all in one place. Just eight cables.
If if were me, and assuming that the eight gangs are all mounted together at each end, I’d run one multicore CY between the switch banks, to save a horrible mess of multiple T&Es. (Unless this is singles in conduit - you don’t say). So long as the CSA is suitable for the total load there’s certainly no need for multiple live cores. And you can always double up and shrink fit.
Alternatively I’d do drops in multicore from a big Wago station to the switches, then take separate T&Es from there to the luminaires.
And leave a sketch of how you wired it in the box - possibly complete with a rude message 😀 - for future electricians.
But that’s just me. I often do things differently to ‘standard’ and am often told on here that I’m wrong, as that’s not how the idiot’s guide tells you to do it 🙄
If if we’re me, and assuming that the eight gangs are all mounted together at each end, I’d run one multicore CY between the switch banks, to save a horrible mess of multiple T&Es. (Unless this is singles in conduit - you don’t say). So long as the CSA is suitable for the total load there’s certainly no need for multiple live cores. And you can always double up and shrink fit.
Yeah, I'm looking at running multicore YY cable between switches. Run in conduit in wall and then clipped in ceiling.
I've never done 8 gang, so never considered lopping the lives. Seems a no brainer, but was not sure if there was a reason not to do it.
Correction:
It's 4 gangs for Lounge and 4 gangs for kitchen, all in same switch enclosure. Kitchen is on circuit 1, Lounge is circuit 2.
Should I join circuits in CU, or is it acceptable to have two circuits in same switch enclosure. Technically both circuits only feed their respective lights ?
Based on the questions you are asking, I would get an electrician in for this work. You could always do the chasing and floorboard lifting. No offence intended, but at least you know it will be done correctly and also certified.
Yup, I know CY/YY/SY is not 'approved' under certain UK regs because, as I understand it, it was too much hassle and expense for the manufacturers to bother. So one writes it down as a departure, used for good engineering reasons and to equal safety standards. British Standards publications are not law, only a guide to one (good) way of doing things.
Otherwise, why are these excellent cables even sold in the UK? ...
I'll argue with anyone that my occasional use of SY is better than say cr@p flimsy T&E clipped to a wall in a public building. The latter is entirely compliant, but that doesn't stop it being cr@p.
I rather like having that earthed braid over everything, cf. Flexishield of which I also use a lot.
I'll argue with anyone that my occasional use of SY is better than say cr@p T&E clipped to a wall in a public building. I rather like having that earthed braid over everything, cf. Flexishield of which I also use a lot.
Trouble is, the earth braiding isn't really doing anything. If you NEED an earthed outer then you would need to use SWA or flexishield.
Correction:
You can have 100 circuits in a switch enclosure if you want.
Correction:
I am a spark....................
By chance have you ever looked behind a switchplate in the hall of any two story house?
Because it's not to any British Standa
Yes, a few lives. But is this the done thing today?
99% of houses today will be wired using twin and earth and three core and earth cable , so mostly houses are wired the same way. nearly every sparks nowadays will feed the switch rather than the light. you might often find 2 circuits in 1 switch on the landing where you can switch downstairs lights and upstairs lights via various 2 way switching
Yes.
In just about every two story house.
I don't think it needs to be stated, but just in case... circuits would remain separate from each other within the enclosure.
Or you get the dreaded circuits being back fed from separate MCBs in the board when some dope has interlinked all the feeds together
Not when it's all labelled 😂
That'll look nice. My mum has a two gang switch in the hall one switch for the hall the other for the landing and for the last fifty years she clicks on and off until she gets the right one. I reconnected it and said near switch hall, far switch landing but it made no difference.
If he w
I bet saved her legs, I be theirs a trench in the carpet.
I couldn't decide whether a pencil scrawl or printed label would look worse, so left that the imagination.
As with a lot of publications of this type while they are not statute documents they can and quite often will be used to support a case litigation
The other problem is that of subsequent EICR's especially if the original certs are lost there will be no record of your departure and could potentially see the installation classed as unsatisfactory due to the non compliant cable and the inspector not having the same viewpoint as you
As previously posted they are control cables that are generally used in industry for machinery control circuits which are under numerous other British Standards
How far would you argue your case with a man or woman wearing a funny wig or the expert witness that they may get to give evidence against you
Every cable has it's limitations as to whether it is crap is open to interpretation, the question that needs to be asked is the cable crap or has the installation method rendered it so.
Personally for me the crap cable is FP and it's derivatives you see it more often than not incorrectly installed so much that IMO it should be banned from use as a safety cable and we should go back to Pyro / MICC for fire alarms
I’m intrigued, how have you seen it installed incorrectly?
If you read the manufacturers installation instructions for FP it should only be clipped with metal clips or ties but so often it is fixed with plastic knock on clips, plastic cable ties and other similar fixings that melt in a fire and allow the FP cable to fall and then it will not maintain it's fire integrity under the BS to which it is tested
Kent
8 gangs of 2 way light switches - wiring
Michaelwgroves,
mainline,
