- Reaction score
- 0
Power fed light switch and all lights test great, as soon as we put the dimmer switches in the Hager rcbo won’t trip, any ideas please
Discuss power fed light switch Hager rcbo won’t trip in the UK Electrical Forum area at ElectriciansForums.net
HiAre you sure it was tripping before installation of dimmers? Sorry, have to ask.
Could also be coincidence it has chosen this point in time to break.
Yes have tested on both cycles.depends what part of the cycle you are testing.
some dimmers are leading edge and some are trailing edge.
have you tried testing RCD on both positive and negative cycles?
most hager RCBO will trip within 1 cycle (20ms) regardless of testing at 0deg or 180deg.
Reply to power fed light switch Hager rcbo won’t trip in the UK Electrical Forum area at ElectriciansForums.net
