sythai
Hi Guys
Recently finished a new build house, 2 levels/ 5 bed.
Wired AICO grade D LD2 system throughout.
LABC has come to sign off saying needs to be grade A system.
Havent got full details, just to chatted to builder (owner of property) on phone.
Did only think this was required on a domestic property when 3 levels+ and/ or HMO ?
Can someone help on this please ?
Thanks Sy
Sounds odd hopefully someone has crossed wires because a Grade A LD2 system will require a Part 1 control panel.
just got bit more info..... when footprint is >200sq meters then also grade A required.
This place is right on the limit of 200sq meters ! and we have pretty unhelpful labc inspector, which doesn't help things 🫤
So what’s the solution? Does it have to be hard wired? Running cable surface? That’s going to look good in a finished build.
Is there a battery solution that can be used?
Hopefully the LABC are mistaken, but it’s going to be an uphill struggle to get them to admit it.
We've spoken to 'fire alarm co.' we use from time to time...... there is a wireless system that would do it and comply with LABC.
Will be pricey though !! Better than pulling £1.5million new build apart to hard wire (which isn't a conventional layout by any means)
Next step is back to LABC to try and negotiate, over to the Architect/ Builder
Does this just apply to new builds… or do same regs apply for a refurb also above 200 sq/meters? Thanks Sy
The rule must have been in place for some time, i remember coming across it on a farm house refurb with extension 15 years ago, property was only 2 floor house, but about 250 sqm so required a grade A system. Be interesting to see if its the architects fault or labc if it was or wasnt on the plans
….. so outcome was!
Architect got on the case and floor space was recalculated using a ‘net’ value which subtracts all the internal walls. This brought it in under the 200msq
And all fine with grade D/ LD2.
Good news for everyone involved😉
(Existing LABC causing grief on all fronts has also been given the boot and new private BC brought in.)
sythai
Devon, United Kingdom
Grade A... fire detection/ domestic property !?
Domestic Electrician Forum
sythai,
littlespark,
