Guest viewing is limited
The boilers you list are conventional , not combi rubbish, so it looks like you probably do have a gravity hot water system, fed from a tank in the loft. Hopefully, the cold water supply to the shower is also from the same tank.
The problem is almost certainly that the new shower has a higher minimum pressure requirement than the original.
It is becoming almost impossible to find taps, mixers, showers, etc. with really low minimum pressures since the rise of the combi boiler and a regulation change some years ago that replaced a minimum flow rate with so called water saving specification.
To make this work, I suspect a shower booster pump will have to be fitted.
There is the other think to check and thats the source of the hot and cold. Typically gravity fed shower mixers require that the cold supply also comes from the same header tank as the hot supply. Its possible that the mixer is not suitable for gravity supply and if the cold is coming directly from the mains it may be pushing past the mixer thus diluting the incoming hot even from the mixer is on full hot.
Suggest ask plumber whether mixer is even suitable for the install..
Here is a "tangent " to the debate ..... !! Ive seen the very reverse . And a child was badly injured .The water came from the shower at full temp causing the child to "throw itself through a shower door . NO matter what .There should be a "master " control that limits showers and taps in homes . I use valves to ensure when taps are open the volume of water entering a basin etc is not to much and sprays all over the place .But also to ensure that people dont get scalded .
We still don’t know if this is gravity fed or not as it could be an unvented tank and the header tank could be for central heating.
Run a hot water tap and check if the header tank ball cock starts putting water in.
Then do the same with shower just using cold.
Can you
exactly .....And God bless the King !
The manual confirms you have the version with a min pressure of 0.4 bar, so it's odds on that this is the problem.
Manual also confirms that there are inlet filters (part #3).
The filter also incorporates check valves, which aren't needed if both hot and cold supplies come from the same header tank. Removing the hot one may solve the problem, to a degree, at least.
Isn't 0.4 very low already? Would I find a shower designed for even lower pressure. Also I should mention in the kitchen the Tap did need replacng cos it wasn't correct bar and just came out as a trickle when hot.
Pretty sure its gravity fed but ill do some investigating.
Some years ago, I used to get promotional literature from the manufacturers along the lines of "our new tap/mixer/shower is the highest flowing on the market.
Cue the rise and influence of the tree huggers.
Now I get literature "our new tap/mixer/shower is the most economical and water saving on the market" which translates as "our new tap/mixer/shower is the lowest flowing on the market".
This is called progress.
Used to be no trouble finding stuff down to 0.1 bar, but these are few and far between nowadays. Still 0.2 bar stuff around, but even then it'll be a poor flow compared to what is considered normal these days. A double ended automatic shower pump is the usual solution.
I've had a few beers tonight with the Mrs, but full marks to Brian for knowledge of showers and BMWs!
Only one degree that's not a lot :)
Another note: I ignored this but she said the shower is hotter when the hot water is switched on at the programmer and yes it does seem to be. Again the hot tap a meter away is not affected as long as the hot water came on in the morning it has hot/boiling water but the shower having the hot water does make it better.
Any ideas?
There's absolutely no point in doing so when a pump isn't involved, but the hot water for a shower is often taken from a slightly lower point in the cylinder than the rest of the hot water, to avoid problems with water being sucked down the cylinder vent pipe and air being drawn into the pump.
This arrangement leads to the hot water to the shower 'running out' a little before the hot water to the rest of the house, which would fit with the shower being a 'little better' with the boiler on.
A pic of the cylinder would confirm.
Are you sure that there isn't a shower pump somewhere, that may be switched off or otherwise not working for some reason?
Thanks again for talking me through - Again I do feel this might have happened since the new boiler but I could be way off.
Is this what you want?
and do you know what this is> it's in a cupboard near the shower room?
If you want higher def pictures let me know.
Its a temp controller for underfloor heating systems. But can still be used
temp control unit designed for underfloor systems .But its fine
ill have a feel of those flexi pipes and see if they get hot?
I think that pump was fitted/replaced when the boiler was. So if the pump comes on with the shower and not the tap - the shower is fed from a different source?
The feed for the shower hot does come from a special fitting that draws the water from slightly down the cylinder, and that is most definitely a shower pump on the end of the pipe that feeds from it.
Follow the flex from the pump to where it connects to a FCU, and see if it is switched on.
Also, check that the gate valve with the red wheel handle, near the top of the cylinder is fully turned on.
Hi yes the pump comes on with the shower. I posted a video above but it's probably not showing :(
With the shower running the two flexi pipes at the front of the pump are warm but not hot
The gate valve is open full - I closed it to see what would happen and it was still slightly warm? maybe cos the pipes were warm.
So I'm guessing something is not right with the feed to the pump. But cant understand why the tap is hot because it's from the same tank.
The immersion heater would normally be switched off. It's only there to a) block up the big hole in the cylinder, and b) as an emergency backup if the boiler is out of order.
The problem with the shower is definitely the non working of the shower pump. Everything that has been discussed before is now irrelevant.
Do you have a non contact voltage detector (Volt Stick)? If so, wave it around the pump cable to see if it is live.
The OP said that the pump comes on with the shower #66
Ah, so that's what that short video was about. Doesn't come over very well on a laptop without sound. Listened to it on my phone now, and it doesn't sound very happy, but having been asked many times to diagnose car faults from videos, I know that's the norm.
The black connectors at the top of the pump flexible pipes often have quarter turn isolator valves built into them. If they are present, are they all fully on?
I've also come across pumps where there are little mesh filters built into the rubber washers between the nuts at the bottom of the flexible pipes and the pump.
All comments about the shower valve having a to high minimum pressure requirement are now invalid. Something's blocking the hot water flow.
I'll just say with the with the immersion heater on it's too hot - on max its like boiling hot - its dangerously hot. I've switched it off for now.
Reading
Trainee Electrician
Plumbing Question - Shower not hot
Central Heating Systems
Mark Wright,
Mike Johnson,
