Not a plumber, look at the poor bends in the pipe, if there is one thing a plumber can normally do well, it is bend pipes neatly.Obviously, a plumber as well as a spark
Looks rubbish.
Looks rubbish.
It would be single isolated inside the switch.Could be double insulated cable inside, if so, do you think there is a requirement for the pipe to be bonded?
But i was assuming the box was attached to the cpc.It would be single isolated inside the switch.
Back box/switch would be classed as an exposed conductive part.
I say yes no difference from a class l light fittingBut i was assuming the box was attached to the cpc.
do you think there is a need to bond the pipe, assuming the cable comes into the box double insulated?
Personally i was thinking if the flex was secured inside the back box with a cable clamp then the tube need not be bonded, if it is free to move then i think the tube should be bonded.
but I am open to peoples suggestions.
He wanted it to have the bent with the knee look.No comment on the earthing, but if I couldn't make a better looking offset in copper tube than that, I wouldn't be putting it on public display.
No former used lolHe wanted it to have the bent with the knee look.
A kinky one, if it was......Obviously, a plumber as well as a spark
Looks rubbish.
And that sheathed cable is connected to a metal clad FCU which is connected to the copper pipe so makes it an accessory point. 411.3.1.1 states this very clearlyVery different from a class 1 light fitting.
It looks like there is an insulated and sheathed cable inside the pipe so there would be no need to earth it, it would be no different to a cable tray or basket in that respect.
The less said about fire alarm installers, the better.Fire alarm system, thank goodness I didn't have to work on it. only one conduit is bused into the control panel, 3 have female adaptors but no bush, one is just poked in and has a cable tie around it. The less said about the dangling pcbs the better. View attachment 110786
The conduit to the call point has no fixings other than the female adaptor in the top of the box.
You forgot, hand on chin and slow head shake from side to side, tends to happen with all trades though.The less said about fire alarm installers, the better.
Most turn up on site swaggering like the fourth emergency service, suck air through their teeth and then turn out rougher work than most people would think possible.
Hands on hips for fire alarm installers.You forgot, hand on chin and slow head shake from side to side, tends to happen with all trades though.
