Left by a wet pants when the boiler spring a Leek, no fuse spur to 3amp, take off the wall and left it has I was when it boiler tripped the RCD.
A flex outlet plate and shallow 16mm wall box, very poor. Are you sure there isn't a fused spur upstream of that Buzz ?
No idea, called out by a company that do
emergency calls, isolation was in order
From main boiler, customer getting wet paints back to sort the boiler out, informed customer to tell wet pants to investigate, and if no up stream fuse spur needs one putting in.
I just love the strain relief at 3:20, the bolting straight through the vibration feet at 9:20 (so they're bypassed transmitting the vibration straight through).
Strain relief is low on the priority list when you have aesthetics to consider, like the colour of the cable.
Can't see any danger with the consumer unit or wiring to the meter around 10:45 though! 😉
In fairness, he did say he used rubber washers under the metal ones. :)
And he and his commenters think he's done a brilliant job.
He's so proud of his work, he feels the need to show off the innards of it.
Maybe he could get a perspex cover for it.
Call out to downlights not working in ceiling, all stopped working together
5x 20w halogen mr11's
Middle floor of a town house, cant lift floor above, unable to locate transformer anywhere
oh, no I know what that means..........
cut a dirty great hole in the ceiling!
