99% of the time that is like a red rag to a bull, come on and show me the disaster of an installation and I can redo it and go home.
sometimes though it is incredible how much effort a diyer will go to in order for it to be perfect, sometimes with one simple to rectify mistake. Those are the jobs where it is a joy to repair and educate at the same time.
Looking again at Tim's image, I don't think a factory fitted flex had been removed. It looks very like connections on LAP floodlights a few years back. They didn't inspire confidence when connection NYY-J or HO7, but in fairness I never did have any issues with water ingress.
I was going to facetiously suggest they rarely lasted long enough to see a shower of rain, but that would be unfair when backed by a 3 year warranty.
Priceless.
To be fair he wanted to know why, and we chatted UV rays and grommet shapes!
I think you are right. It would have been a sod to terminate, so some respect is due that it worked at all, for a while!
My current habit is Collingwood units. They seem to be lasting well. Also easy to fit (as are their bathroom bulkheads)
I have been asked to wire an Air Source Heat Pump for a Koi pond - no biggie from the electrical point of view.
However, I thought I would check up on the required settings, and plumbing - just in case there is anything special for this application, so came across this video:
I just love the strain relief at 3:20, the bolting straight through the vibration feet at 9:20 (so they're bypassed transmitting the vibration straight through).
Can't see any danger with the consumer unit or wiring to the meter around 10:45 though! 😉
And he and his commenters think he's done a brilliant job.
Left by a wet pants when the boiler spring a Leek, no fuse spur to 3amp, take off the wall and left it has I was when it boiler tripped the RCD.
A flex outlet plate and shallow 16mm wall box, very poor. Are you sure there isn't a fused spur upstream of that Buzz ?
Reactions: DPG and nicebutdim
No idea, called out by a company that do
emergency calls, isolation was in order
From main boiler, customer getting wet paints back to sort the boiler out, informed customer to tell wet pants to investigate, and if no up stream fuse spur needs one putting in.
Reactions: Dave OCD
Another can you put a few down lights in.
Strain relief is low on the priority list when you have aesthetics to consider, like the colour of the cable.
In fairness, he did say he used rubber washers under the metal ones. :)
He's so proud of his work, he feels the need to show off the innards of it.
Maybe he could get a perspex cover for it.
Reactions: Julie.
What to do when you find one of these on a job
That metering arrangement would be very nice to have. :)
  • Funny
Reactions: DPG and pc1966
Call out to downlights not working in ceiling, all stopped working together
5x 20w halogen mr11's
Middle floor of a town house, cant lift floor above, unable to locate transformer anywhere
oh, no I know what that means..........
cut a dirty great hole in the ceiling!
Hide all your wiring sins under a ton of insulation, just in case someone sees it.
I have but one question @mainline ... the first picture, is that cigarette ash or a scorch mark in the center??? :D
It could be crushed mice poison, :) I'm back there Wednesday, I will have a look.
Reactions: SparkyChick
Found something similar too last week and daren't look beyond the black tape!!
8K
Darkwood,
mainline,
