Discuss CCTV what coaxial cable needed for Hikvision DS2CE72KF3T-E in the UK Electrical Forum area at ElectriciansForums.net
Hi what cable make and size would be needed for hikvision cctv cameras 2.8mm model number DS2CE72KF3T-E
picture provided
They're not power over co-ax are they, in my opinion never do it this way. I don't mind co-ax CCTV, the picture is just as good as the POE cameras but I would always run separate 12V power to cameras (even the POC cameras have a separate 12V connection. The one and only time I tried POC I had nothing but trouble with the cameras losing connection, you just need the slightest movement on the BNC plug and the camera goes off and re-sets itself constantly.
Reply to CCTV what coaxial cable needed for Hikvision DS2CE72KF3T-E in the UK Electrical Forum area at ElectriciansForums.net
Hi, I have a coaxial wall plate that is hanging off the wall and needs replacing. How do I wire the old plate which has an IN and OUT for the...
Client currently has a DB in his outhouse. It feeds a pool pump and an air source heat pump. It is currently being supplied using a 4mm T&E cable...
Hi guys Iam currently studying for my level 1 electric installation . Which btw I am loving. I've always been decent with DIY. But also I have...
Just received a Eufy CCTV floodlight camera (This one) which requires existing wiring. We have two outdoor lights on the side of our house with a...
