This one is just strange.
Crabtree Starbreaker box, Hager main switch, CGD RCBOs, one Fusebox MCB, bus bar fed from bottom of main switch into one of the RCBO's by that red wire underneath.
What irks me is that it's all fairly neatly done....can't be DIY...someone knew what they were doing here.
I would imagine the person responsible for the installation of the Fusebox MCB is also responsible for tampering with the bus bar and the link cable!
Considering that starbreaker board would come with a plug in bus bar, it's more likely whoever installed the Hager & Lewden gear tampered with the bus bar - otherwise nothing would have worked.
Wiring up for an ASHP yesterday. Plumber had been in before and had his apprentice repurpose and wire the existing immersion supply. Bless, at least he tried.
I later found the immersion was wired from an existing ring final. Had to open the JB to remove cabling (then rana new circuit). Think that vermin family all died together.
What's the minimum bending radius for 4H4 MICC again?
Another view, the other end of these cables is very nicely installed and I can only assume this end was once. It hurts seeing stuff like this. There is no excuse, especially as these are all metric cables with new pots and glands readily available. Even if they were old imperial cable there is no excuse. Out of view some of the other cables are too long so loops have been buckled into them to 'shorten' the cables. Pathetic.
Any MI installation that use plastic cable ties is likely to be a rough job in more ways than one
And that installation is dog rough
To add insult to injury the tie tails have all been roughly cut off leaving sharp edges everywhere.
