In built test facility? (Unplug it)Never seen this label configuration before or the 5A plug and socket
The pictograms on the right clearly states:- “in the event of fire, run around in a circle in blind panic”
Looks like you buy the one emergency exit luminaire, and select the appropriate signage rather than having to buy the correct luminaire with the correct sign for each application.Never seen this label configuration before or the 5A plug and socket
Agreed. Like this:Looks like you buy the one emergency exit luminaire, and select the appropriate signage rather than having to buy the correct luminaire with the correct sign for each application.
Very Benny Hill.Agreed. Like this:
It's an MK 2A 3-pin plug. Familiar to me amongst the assortment of round pin plugs and adapters in our house when I was young(ish)!5A plug just looks like a standard BS 546 type d to me, what is it if its not?
That's a 2A BS 546 plug, so same range just 2A rather than 5A as the OP indicated.It's an MK 2A 3-pin plug. Familiar to me amongst the assortment of round pin plugs and adapters in our house when I was young(ish)!
We had them in our rooms at university - the town centre Woolies did a good trade at the start of each academic year. Plus there was a second hand market selling your surplus plugs to freshers when you'd moved into more modern digs.That's a 2A BS 546 plug, so same range just 2A rather than 5A as the OP indicated.
2A is pretty rare TBH
I was scrolling down and half expecting to see a 2A socket on the ceiling.I took the ceiling light out in our lounge and put in 2A sockets.View attachment 117525
To be fair, it is at least a decent bit of workmanship. The front complex bend is a bit wrinkly, but some would have used "a lot" of elbows to do it.When a plumber completes a heating installation in a new build, then realises he’s got the flow and return the wrong way round….
