This one is from a handyman. Not a joiner. But someone who can turn his hand to anything….. ok, that hand must have a boxing glove on it looking at this.
Nice custome made cupboard to hide the meter and the consumer unit…..
Unfortunately…. I’m going to have to ask them to remove it….
Cos I can’t get the lid off the box now.
He should use cabinet hangers, so it could then be simply lifted off.
He should have left it until I was finished.
I’ve still got main bonding to get back to here.
Whole job has been arse over elbow. Customers dad was painting walls before anything had been done
Had a call the other night from a mate whose van was dead after turning it off a few hrs before.
He had tried jump-starting but still no crank/start.
After a 20-mile journey, it took me around 30 seconds to see why.
T'was found in a rental property several years ago, I was sent to see why the lights had failed and the elderly tenant fell, requiring an ambulance and hospital stay
That just looks like a bucket of cuttings for the scrap.
Is that a relay contactor? What was that doing in a domestic?
Most of that was very much in use, the relay appeared to have been to do with a removed linear floodlamp, linking it to other outdoor lighting.
The fault wasn't in that jumble!
A colleague found this during a PAT on a builders welder back in 2012, the white cable was on the welder
Initially he was just going to change the blue socket (wrong gender) on the welder to a plug and put the blue socket on the black cable, however the white cable
The full extent of it wasn't found until I exercised a screwdriver:
Blue socket wired incorrectly (L= blue, E= brown N & earth not connected) and no cord grip, yellow plug altered to fit into the blue, yellow socket (used as a join) no cord grip, 13A plug not sleeved and what doesn't show in the pics is the black rubber cable was brittle and cracking (perished).
However the yellow cable was almost pristine and repaired as a 110 extension.
Oh and of course the user didn't think there was anything wrong with it other than sometimes tripping breakers, but the boss apparently gave him grief
July 2024, rental property:
Tenant has been there since 2018 and Agent arranged EICR, landlord blames tenant, tenant showed me the Estate Agents papers from 2018 where that can just be seen in one of their pics and of course a line saying the electrics needs updating. It's a 10mm² T&E from the cutout.
That piece of electrical tape needs removing because it makes it look untidy.
Good to see the rubber covers still in place over main switch tails.certinaly could cause a nasty shock.
It's a wonder the dno never just used a wet piece of string from cutout.they do as they please wheneverer it pleases them
