R
roukel01
my example were not in the same building, in fact probably over a 6 mile radius,.. hence the duplicte ID's
Sorry ambiguous post, when you said different departments didnt realise you meant different locations to that extent but have known things been moved between departments before like extensions etc, but yes it is all overboard in the way im stressing it but its means if their is an unfortunate death from an tested appliance then your records will be scrutinised and duplicated item even over seperate departments within the same company could make the difference between liability and no grounds for blame...... yes a very unlikely senerio but if someone can win the lottery then it has to work the other way too.my example were not in the same building, in fact probably over a 6 mile radius,.. hence the duplicte ID's
At the end of the day, nobody takes PAT testing seriously
lol
