classic. but would have been funnier if it had been a plumber.
Had a rat poke its head through a downlight hole once - i`d taken it down to test why it wasn`t working and went to put it back and Roland was staring at me, it turned out there was nest with 5 rats in it built around the transformer, keeping them nice and warm till it started cutting out on the thermal trip
Was doing a house refurb. was in the bathroom with the plumber who was working behind me & the nob decided to lift a large cutout chipboard flooring right behind for somethin & didn't say a word and you've guessed it, i've turned around and ended up in the downstairs hallway.
Quality mate..
Motor control centres (posh name for panels) in water treatment works always have mice and rats droppings in them. i now bang the panel trunking with screwdriver before i pull the lid off, so all the droppings fall out. it stinks too.
Myself and a couple of our lads did a complete rewire of a local knackers yard / farm about 2 years ago .
They had not long taken a new contract on and were snowed under and could not shut down , they had booked us to install a third incinerator already but not for 2 weeks and they were getting a bit behind .
They could take about 20 ton a day but were getting 25 - 30 ton of " product " a day on top of the usual so things did not smell good !
The " product "was dog , and i for one did not realize how much fat is in a dog !
While they were burning , it was literally pouring out the front of the incinerators and running across the yard , they kept chucking road salt on it to soak it up / stop it burning .
We knocked the power out twice by mistake and truly got smoked for a good 10 mins each time , on a separate note if they lose power for too long the heat will melt the burner motors !
Anyway the worst part was the main cable run which had to go past in front above the two incinerators and we had to lay all the swa through the running fat for the pull in , we got absolutely plastered i can not even begin to describe the smell or taste .
I remember in the evening when we had finished and washed up before leaving i was heading down the drive and brushed my hand through my hair and rubbed it across my cheek and when i looked in the mirror it looked like some one had poured olive oil over my face , thats how much fat was in my hair !
Needless to say all work gear got burnt after that job .
We have done numerous other not so pleasant jobs but from what i remember at the moment this the worst .
i know that smell worked at pointons in chedleton i heaved on the 1st visit
mine was probably while wiring up a roller shutter door about 6 years ago when the roller shutter door was down setting the bottom limit a forklift smashed into it bringing the entire shutter down 9 metres high by 7 meters wide just missing me it was a brown trouser day that day
didn't that used to be called something else, beginning with G.... i went there for an agency once, after 3 steps inside, i turned round and went home.
Here we have to be careful of sump pits, the normal thing if your opening a sump is is throw something large and heavy down it that makes a noise and gently go down with very bright lights.
The best myth over here is the poor Filipino lad that got attacked by a nest of camel spiders, just google these things they can be huge, and he died apparently of multipe bites, yet to be proved.
I also heard from a college that one of his lads got bitten by an Arabain Cobra out camping, though he survived he was not very well ...........
Mine was bats, we were doing an old oast house in the 80's and the place was full of them as it had been abandon years before.
even funnier if it was a Plasterer
best would however be a building inspector
not sure always known it has pointons but a spark died on there few years ago trying pull a fitter out of a machine the fumes killed him the boss narrowly escaped prison with a hefty fine since then theyve been hot oh H&S
