S
Sam7
Hello all
I want to add an outside light (not a security light) to the existing lighting circuit in a Bungalow.
The light is already there and WAS just plugged in via a 13A plug to a socket.
After re-plastering, the wire was cut so only approx 1m of it now comes out of the wall into the room. No socket is reachable.
I therefore want to now add it to the lighting circuit.
Q1: Do i need to connect the wire to a fused switch ,then to the circuit or is a normal switch ok ?
Q2: Is it ok to come straight off the ring in the loft or does it need to come off of a ceiling rose ?
Any advice or links to diagrams would be a great help.
Thanks Sam.
you have 2 options.
1. come directly from the lighting circuit. disadvantage is that in the case of a fault on the outside light, the customer can't isolate it.
2. fit a D/P FCU to the ring, and fuse down to 3A. this is the best way, as by switching off the FCU, the customer can isolate the outside light, thus saving you a 2.00 a.m. call-out.
If i fit the D/P FCU to the ring, and fuse down to 3A
can i still come off the light ring...as my poorL1.gif diagram shows.
if you come from the lighting circuit, no need to fuse down, just a light switch will do. however, i question your competence to do this when you refer to a light "ring".
light is already there. just needs reconnecting to supply as was orig. on a plug.
Sam if you have RCD/MCBs in your CU then putting a 3amp BS 1362 cartridge fuse in the circuit will do absolutely nothing, as the RCD/MCBs will trip long before that fuse even thinks about it.
As Tel as said you can do the job in 2 ways come direct off a light circuit, but any fault/maitenance will mean the whole circuit will be taken out, and it's sometimes not a good thing to have outside lights on this
Or as Tel the best way is to take it off a socket circuit via that fused FCU
i am not an electrician so my terminology maybe suspect.
because of the way all lights come off of ceiling roses, i wanted to know if i had to add this light the same way OR if i could just come off of the existing circuit.
and if by doing so, did i need a fused switch or a standard one.
Dillb- light has been on wall for a while so no manufacturers instructions.
Ahh right, thought it was a new fitting :oops:, still need to take the load into account even before connecting it to any existing circuit.
sorry guys , typed previous reply then read new ones.
OK ,i'll add a D/P FCU to the ring then connect.
and i'll leave the lighting 'ring' well alone.
Thanks for the help.
Wouldn't it be classed as a outside light therefore is notifiable?
No, not if there are no exposed outdoor connections, and the work doesn't involve the provision of a new circuit, or extending an existing circuit in a bath/shower room or kitchen.
