Hi, Was interested to see this forum as I also have this problem but I am using the GJD Emerald controller and the lights still come on during the day. Any help would be gratefully received as this has been puzzling us for months and we've tried all the different settings possible. HELP!
Are you getting any voltage fluctuations?
Yep, done that. It made no difference where we set the level on all 4 detectors the lights still came on.
id have another look at the controller,take the panel off and have a look at the pulse count dial,it may be set to the man symbol,the dial isnt great to see,total left is walk test then pulse 1 2 or 3 as you turn it right
If your getting voltage fluctuations enough to make the unit drop out and then believe it is on start up again, this could be your problem.
opal controllers wont power the lights on if they lose power and power up,it could be a faulty controller or its not set up right
james the spark,
alarm man,
