T
tojo$mojo
Morning Forum,
i am looking for some help reference the correct wiring for my thermostat i am making a home made incubator. I am a little confused on which way round the cables should go. By the way its 220v.
i will attach the a photo of the thermostat if that helps.
Ok bearing in mind that advice is just advice,I would say live and neutral in go to terminals 3 and 4 temperature monitoring probe to 7 and 8 and switched live to heater goes across 1 and 2 cant read the language though so not sure what max load would be across 1 and 2.Do you not have manual?
sounds right to me. are terminals 5 and 6 for elv dc (12 - 24V), or is that the rating of the switch?
L and N in on 3 & 4 . sensor on 7 & 8. then 1 & 2 switch. L to 1 and switched L to heater on 2. N direct to heater. do not wire N to terminal 2 or it will go bang.
hi
i have just made a drawing as to what i think it should be like, from your kind explanation, i think its still wrong please be kind and sorry in advance for trying anyones patience.
Digital heat Controller wiring help required please anyone
tojo$mojo,
tojo$mojo,
