P
paddyscouse
hi can some one advise me what to use for a radial socket circuit, i was thinking about 4 mil with a 32a mcb for kitchen
would then 2.5 with a 20a mcb for other room and the same for upstairs x3 beds
each to there own in this instance
mind you 32A radial in a domestic kitchen is hardly going to have a volt drop
i dont give a damn either lol
come to think of it i have in my house a 20A radial to each bedroom and loft
kitchen a ring circuit (had no 4mm at the time) lol
& lounge and dinning a ring circuit
I think that sometimes people install radials purely because they don't know how to test an RFC properly, and certainly don't understand what all this "cross-connection" mumbo jumbo is about.
I have spoken to many "electricians" over the years who have never even heard of ohm's law. One I was speaking to last year even thought it was an American cop show!!!
Spot on!!
Rings Vs Radials ...........? Rings
Pro's and con's........... There the british way! - none of this euro crap! - Come on ENgland!
Discuss.......
I was expecting more scientific / technical theories lol , oh well its a start
I'm in the radial supporters camp but i'll give the ring fanboys a head-start ;-D
Rings have never been the same since we went over to this rubbish single-core cable.
Would love to see T&E tri-rated. Imagine double bootlace ferrules on an RFC. No more battling to get the cable into a shallow backbox someone has fitted. :)
I like radials, in the right situation ! but knowing that the one major potential drawback of radials is where accessories, sockets or FCU's etc are connected in line is loss of earthing further up line if a cpc snaps off down line, yea I know it's tested but some numpty doing a socket change might not test it, I have always thought it was a shame they never made a T& E x2 so two cpc's and two L's a bit like high integrity earthing would work on a ring arrangement, dual earth sockets, cpc's split at sockets and fcu's, I don't quite know how they could keep the copper apart in the sheathing tho..
ATB J
i agree to a certain extent but i like to change the mix now and again and keep the lads on there toes as we do new houses,
i would be boring to do rings all the time in kitchens
Most countries being, or past commonwealth countries, others accepting BS7671 as a recognised standard*. The later category covers a multitude of countries, which includes China, as many of our final circuits are Rings, as well as on my last project in China.
India, Pakistan, Cyprus, Hong kong, Singapore*, Malta, Gibraltar, Suadia Arabia*, UAE*, Bahrain*, etc etc!!
Very interesting, Ive always been led to believe it was just us with rings in the world,
However its more like just us with rings in Europe then
Nice info there.
Yes , noticed singapore has identical wiring system to the UK when i visited last year , even the same square 3 pin sockets / plugs.
try purchasing the BS 7671 then in china from a book store (not ebay) also at what price i reckon they would be £5 over there not the £65/£75 over here
I think sometimes what you say is correct but this argument is something that is always brought out with people like E45 when they are losing the argument! Heard it all before, boring, boring!
Sorry to bore you TC. Play some music and refocus that zen :)
Btw, thank you for recognising that "sometimes what I say is correct".
another question for you guys if i am working with a tt system what will you do to calculate my ze r1+r2 with my zs
Don't do anything other than measure your Ze mate. I'm guessing you have te terminology mixed up a little though, the formula is Ze+(R1+R2)=Zs
So in your case it will be, measure the main earth loop impedance(Ze or Ra) then either add your (R1+R2) or just measure the Zs.
no my online friend my formula is the same as yours just wondering without looking in book will thease high readings be acceptable as, im sure its 200ohms in book
You may need to borrow Tony's thing there mate.
Now this is just my opinion and that of a few others, and that opinion will be contradicted by some but that 200 ohm figure in the regs is nonsense. With a little bit of thought and effort a Ze/Ra in the region of a TN system is easily achievable. All you need to do is remember depth is your friend with a TT, depth and the fattest rods you can buy.
Imho 200 ohms is not an acceptable reading upon which to base your earthing the best I've ever gotten on a TT was 0.29 and it didn't take that much work.
Because each leg of a ring needs to carry 20a, and if covered in masses of insulation, 2.5mm won't be up to the job. Hence the need for a 4mm ring......don't get me wrong, a 4mm ring is a horrendous concept, but now and again has proved necessary!
A real pain in the backside if you find yourself in this situation. I always do everything possible to avoid it, including installing conduit where builders tell me "it's not necessary".... Like they know what the hell derating factors are. (apologies to any builder reading this who does know about cable factors)
Builder : Why are you putting the cable in that conduit stuff? My usual electrician just tacks it to the wall and we plaster over it.
Me: A) Because it keeps the plasterer from taking chunks out of it, and B) Because I can take the cable, inside its conduit, straight through your 24" of insulation. Next question...
I've had time to consider this otherwise informative post and have a point to raise ;
Although these countries may use BS7671 as the basis for their own wiring regs , that doesnt necessarily mean they use ring mains as a standard wiring arrangement within domestic installations ??
They could still be using radials only as per the European norm.
There's a good chance Eng has installed RFC's in those Countries mate :)
socket circuit
paddyscouse,
Dave 85,
