- Reaction score
- 4
Im an electrical apprentise just about out of my time been working for 2 years now mainly as a mainternance engineer, but do lots of installs and panel building etc. Here is my latest Panel if any of you wonder how plywood cable drums are made (Well the Larger ones) this is how it is done. This is a new hydraulic press which operates at 200 Bar. The panel operates the pneamatic control to take the drum in to the press and eject it once pressed, the hydraulic enerpac aswell as a full automatic mode. There are a number of conditions for press to work including light guards and pressure switches so the drum is perfectly pressed. I designed and built the control circuit. Here are some pictures. Unfortunatly none of the completed panel as i forgot and it has already been installed in another factory.
This picture if of the press under going trials it was then stripped and transported to another factory where we installed it.
Ash
Ash
