G
grantr37
with modification and more expensive components (some surface mount SMD Device etc) this circuit could be designed to run entirely on battery power or even the small 5v 100mA rail provided by the USB device, although this would eat the batteries more quickly.......if you are looking for it to turn on and off an appliance for example without the Android device being plugged into a mains adapter and operating on internal batteries only....or you could even separate the device from the Android minicomputer using a Bluetooth module either internal or one of those tiny little low profile Bluetooth tranceivers that come with a wireless optical mouse plugged into the USB port (again a bit more expensive) but for USB alone it can be done really cheaply...
the separated Bluetooth receiver unit if used could be powered by an internal rechargeable battery and that could in turn be charged by using an inductive coil based charging circuit taking energy from the outer part of the supply cable without any physical connection...so it could be clipped onto the supply cable next to the appliance....as a plug adapter for instance...
