D_Hurst
Hi - very new to this forum but having had a look at some of the previous posts - this is probably the best site for me to get some help.
I have a lighting circuit i my garage (1 light activated from 2 switches) and i need to add an additional light to this circuit. I think it is as simple as running a 1.5mm cable from the current light to the new one but am probably wrong.
If anyone can offer any advice it would be great - in terms of skill level, i don't thnk it's beyond my capability but i have been given a couple of estimates of £100+ which does seem a little extreme !
well £100 not that expensive especially if its a vapour proof flourescent fitting, labour traveling to site when you look at the costs involved its a reasonable price , it is simple 1.5 to next fitting joint cables to appropriate terminals and the jobs done , but if a spark was to do it then you would get a Minor works certificate
depending on light fitting, length of run, etc, the price will vary. It is as you say joining one light to the other.
£100 for 1.5M of 1.0 T+E and a batten lanp holder (which is what he'll end up with) is a bit steep.
Minor works? "What's that?"
Minor works is Ye Olde fashioned chimney sweep trainee.............or the average factory worker in india
If it was near me I'd charge an hour and half for the first hour (£39) plus bits. so a fiver for a batten light and a bit of 1.5. £44. £100+ is steep
