Deservices
He would also do the design based on what they wanted. But as he's not stated they didn't want RCD protection, I would also of fitted one if not been requested not to. but of told them possible trips and adjusted needed ie maybe run a few radials.Now I am not getting involved in a argument, but it is down to interpretation. IT equipment will leak to earth therefore causing a RCD/RCBO to trip if to much is installed on one circuit. This is what the OP wanted to avoid. Now the sockets wont be used or constantly monitored by a skilled person. As to do that would be bloody expensive to employ effectively retail assistants.
The customer has not stated they dont want the sockets RCD protecting as again the OP has said he has done the design, install and testing.
So the only way I see it possible to do this would be too.
A. Work out earth leakage of each item of equipment
B. Install enough circuits so that none reach the limits of nuisance tripping
C. Install each circuit on a RCBO
