it probably happened because you went short circuit with `it`....
and they are an `it` n all.......
how dare you come in here and start waving such a nasty piece of work in front of us....lol..
glad you did actually as this is clear evidence of just how grotesque these artefacts to incompetance really are....
throw em, break em, smash em ......wherever you find em.....
I'm impressed with that ... I really am !!! :)
So... I touched it on something I shoudn't have whilst it was still in contact with the live terminal? I've been using it to test the means voltage this way for weeks and this hasn't happened before. What did I do wrong this time?
What you did wrong this time was exactly what you did wrong last time - you used a neon screwdriver - the difference is last time you got away with it & this time you didn't !!
Neon screwdrivers should not be used for anything more technical than stirring tea or poking holes in plasterboard !!
Get yourself a proper tool for the job and learn how to use it. ;)
mines a ck one and cost 3.50... but all chat about these being bad for health and they seem to be everywhere for sale even the pound shop with connectors and pvc tape all in one bag
How much do they sell for in there as a pack?
I always get those things free, what a load of crap, I use mine as a knocking driver about all it's good for, they don't even meet the spec for testing equipment as they have a large exposed tip. Stop buying crap from the pound shop and get yourself some decent tools
i hope you didn't pick mine up by mistake geordie. i use it for scratching my arse!
I was trying to check whether the fused spur is part of the main loop (it looks like it is - it has 2 twin and earth cables feeding into one of the "input" set of the live, neutral and earth terminals, and one twin and earth feeding from the output to a junction box which isn't feeding anything)
Just to add, the fact that there are two cables into the FCU "input" does not necessarily mean it is on the ring (loop), it could be a spur that someone has then taken a second spur from, don't assume what is already there is correctly connected ...
Aye ..... I always think that if you're to assume anything, assume that it's wrong until you can prove otherwise. ;)
No, what I meant was that there are 2 fused spur switches which don't appear to be doing anything...so I wanted to know why they are there (hence testing them - not the voltage tester)
It then feeds to the next socket, which then feeds somewhere else, so I thought it's likely to be part of the loop. Should you take a spur from a spur, and if so, how many times can you do that?
you can, as long as they're appropriately fused. if they're not fused, then you're only allowed one spur from one socket.
That's why I mentioned it mate. Surely there is a point where well meaning help runs the risk of giving someone misleading advice through only having partial facts?
I agree.
That very thing has been discussed and argued on this board many times.
I agree.
Uh huh. I'm all in favour of well meaning advice, I've seen it stop people in their tracks before they get fried but tbh, I do have concerns when I see a shorted neon screwdriver that the owner asks why it happened then gets advice on spurs. Jeansie, this is no way intended to be a dig at you but really if you don't understand the basics please get a spark to help.
