First one I looked at
5.1 A 30mA residual current device (RCD) must be installed in all UK electric and pumped shower circuits. This may be part of the consumer unit or a separate unit.
6 A 45 amp double pole isolating switch with a minimum contact gap of 3 mm in both poles must be incorporated in the circuit.
6.1 It must have a mechanical indicator showing when the switch is in the OFF position, and the wiring must be connected to the switch without the use of a plug or socket outlet.
http://www.tritonshowers.co.uk/media/1180125/aquatronic 3 ultra.pdf
Second one
5. A 30 mA residual current device (RCD) MUST be fitted. This may be part of the consumer unit or a separate unit.
6. A separate, permanently connected supply must be taken from the consumer unit to the Mira Sprint through a double-pole switch, which has at least 3 mm contact separation. The switch can be a ceiling mounted pull-cord type within the shower room or a wall mounted switch in an adjacent room.
http://www.mirashowers.co.uk/onlinecatalog/pdf/1076783_w2_b_mira_sprint.pdf
Where do you get your showers?
Second one
