B
brucelee
I believe that there is.
Is there wish I had known that mate just recently fitted a3A FCU & 3 pole pull switch isolator high level out the zones for a fan in my bruvs bathroom as manufacturers stated 3A fuse
so a 3 pole iso with a fuse would have been ideal
its got to be safer now than the fan it replaced as that was wired in 1mm direct from the shower pull switch which was wired in 6mm and fed from 32A Bs3036 the 6mm was also tapped off with a Jb hidden and 2.5mm out under boards in loft to a old FCU in bedroom which used to feed to the old central heating system all still connected even though fan had given up long ago , central heating has been replaced and moved to new location and shower had now been replaced with a thermostatic mixer tap Type shower as the shower had given up the mice had also been at cable at some point also No RCd old wylex wooden backed Fusebard well open wooden backed with Bs 3036 fuses 4 way each way stuffed with as many cables as could possibly ft for various circuits
