C
capitolltd
Shouldn't the lights be tested at a time of low risk to allow time for the batteries to be recharge in accordance with BS5266? Why would you need the lights to then remain on?. Generally unless an indicator is wired into the circuit to indicate emergency testing, switching off all the lights is the preferred method as this reduces the risk of the lights not being re-energised after test. However, the designer will identify the risks and design accordingly.
Those electricians that undertook the old AM2, would remember the wiring of such a neon at the switch position during the exam.
