Shouldn't the lights be tested at a time of low risk to allow time for the batteries to be recharge in accordance with BS5266? Why would you need the lights to then remain on?. Generally unless an indicator is wired into the circuit to indicate emergency testing, switching off all the lights is the preferred method as this reduces the risk of the lights not being re-energised after test. However, the designer will identify the risks and design accordingly.
Those electricians that undertook the old AM2, would remember the wiring of such a neon at the switch position during the exam.
theres no talking to you Adam , every debate ends in a --- for tat childish strop where you have to have the last word.
All I said was it would be easier to test the lux level of the emergency lights if only the emergency lights were on.
Maybe I sometimes embellish my hypothetical scenarios a little, but on the whole the ideas are perfectly feasible and I don't know why you can't get your head around them.
Take this one - "light diffusers might get dirty". What is so bizarre about that? It happens all the time.
well if you clean and lamp change the emerg lights on a regular basis you dont need to turn the lights off for the whole building just to see if light output has dropped.
its called preventative maintenance - fix the problem before the problem occurs.
its a very simple concept.
ffs.
Em lighting needs to be planned well, if u mess up the wiring it can cost u a lot of time(=money) to fix wiring issues.
It is all client based with regards to preference of how it is tested, u need to wire it with the client and regs in mind.
General rule of positions is change in level or direction too remember.Clients sometimes don't know we're em lights need to be positioned.
ffs.
I know what preventative maintenance is thank you, but no amount of cleaning the diffuser and changing the lamp every year is going to stop a luminaire becoming less efficient over time. It seems it would be far simpler just to only have the emergency lights on and walk around with a lux meter so you have an actual number to work with; when it falls below a certain level that's the time to change the fitting.
I also think the em switches should only knock the power off to the em lights, this leaving normal lights on. You can always manually turn these off to measure the lux levels.
other side of the coin, em lights in areas with windows letting daylight in, how can you wire the em switch to knock the sun out?
that just sounded like a load of white noise to me.
