That's probably the kind of post that can only come from someone with the title of 'forum approved troll'.
not really , anyone can come to the same conclusion as me.
at least youve proved my prophecy in post #14.
and goodnite....
I can't recall anything regarding isolating a pir, u could always call the main breaker as a means to isolate :)
You could do, or you could use a key switch. Either way all the lights will go off and the emergency lights come on.
so you went back a full topics page just to look for a thread just to have the last word in ?
lol.
lol.
No Biff I'm not "trying to have the last word" and I never was - you made that up yourself. What I'm doing is participating in an electrical discussion which is why I come on this forum, unlike yourself who only seems to come here to be a pain in the backside.
I've seen it both ways as the rest of yous, council offices have non maintained so normal lighting stays on and preventive maintenance is what happens in these buildings I.e change lamps if discoloured clean fittings if boggin, then other places have emergency light built in and all lights go out, can honestly say lux levels only matter at design stage. From what I've seen. But maybe you have seen different and lux levels matter. Troll 1 Adam 0
And to know what lux levels are required and how to achieve them requires relux, and knowing the photometrics of the unit you are installing the area size you need to cover so relux can tell u were to position em light units.
Or like most of us place over exits, change of floor level and direction and put a few extras in long corridors or large office spaces.
Why do you think you do preventative maintenance if, as you say, lux levels don't matter once the circuit has been designed?
This is like saying you don't need to do any testing on any circuits because it's been designed correctly, or more likely used the pre-designed off-the-shelf circuits out of the onsite guide.
in 20 years of commercial work i have never seen a lux meter being used during the maintenance or testing of emergency lights.
so its not really a massive issue is it ?
