A
Adam W
That's probably the kind of post that can only come from someone with the title of 'forum approved troll'.keep going adam , each post is getting more ridiculous and desperate.
How do you switch them off if they're switched using a PIR detector as in many offices?yes, so if your doing the same test and need the normal lights off, you switch them off and carry out the test as you've just suggested.
shouldn't lights being controlled by a pir have a means of isolation anyway?How do you switch them off if they're switched using a PIR detector as in many offices?
You could do, or you could use a key switch. Either way all the lights will go off and the emergency lights come on.I can't recall anything regarding isolating a pir, u could always call the main breaker as a means to isolate![]()
No Biff I'm not "trying to have the last word" and I never was - you made that up yourself. What I'm doing is participating in an electrical discussion which is why I come on this forum, unlike yourself who only seems to come here to be a pain in the backside.so you went back a full topics page just to look for a thread just to have the last word in ?
lol.
Why do you think you do preventative maintenance if, as you say, lux levels don't matter once the circuit has been designed?I've seen it both ways as the rest of yous, council offices have non maintained so normal lighting stays on and preventive maintenance is what happens in these buildings I.e change lamps if discoloured clean fittings if boggin, then other places have emergency light built in and all lights go out, can honestly say lux levels only matter at design stage. From what I've seen. But maybe you have seen different and lux levels matter. Troll 1 Adam 0
