yes if you had just fallen in a swimming pool so wet and chlorine was in your eyes making it hard to see
Come on, were talking about the incomer which is protected at the supply transformer by what? 200A 250A 300A etc,different ball game.
isolate the load....
wear appropriate safety gear...grap it firmly with plastic pliers....drag it out...
jesus wept...whats the issue here...
If it wasn't dangerous why should DNO engineer's wear IR gloves, gauntlets, full face protection and flame retardant clothing.
I've found that once the first Marigold has permanently welded itself to ones hand, any further flash burns have very little effect. You get used to that rubbery smell.
Most of the WPD lads around here wear 501's and a smile. Raybans for hot days only.
the point i`m making is pullin a bastid fuse has gone epic....
and i dont buy for one second that most in here havn`t done it because of `elf n safety`...so stop blaggin....
We'll all be tripping up over garage forecourts next week - best be banning those pesky kerbs and not minding when the alarm goes off.
60-100amps will f$*k you up!
isn't 30milliamp the upper limit of safe!
work safe, sensibly, use your skills/knowledge/training as you would always when working with electricity.
(its a fuse).........................
I supply my guys eye protection for when they clip cables, as yet no one has worn them for this, not because it cant happen but how unlikely, but if someone loses an eye not my fault I supplied eye protection
