Discuss main cut out fuse in the UK Electrical Forum area at ElectriciansForums.net
I've found that once the first Marigold has permanently welded itself to ones hand, any further flash burns have very little effect. You get used to that rubbery smell.
If it wasn't dangerous why should DNO engineer's wear IR gloves, gauntlets, full face protection and flame retardant clothing.
Most of the WPD lads around here wear 501's and a smile. Raybans for hot days only.
the point i`m making is pullin a bastid fuse has gone epic....
and i dont buy for one second that most in here havn`t done it because of `elf n safety`...so stop blaggin....
We'll all be tripping up over garage forecourts next week - best be banning those pesky kerbs and not minding when the alarm goes off.
Come on, were talking about the incomer which is protected at the supply transformer by what? 200A 250A 300A etc,different ball game.
60-100amps will f$*k you up!
isn't 30milliamp the upper limit of safe!
work safe, sensibly, use your skills/knowledge/training as you would always when working with electricity.
(its a fuse).........................
I supply my guys eye protection for when they clip cables, as yet no one has worn them for this, not because it cant happen but how unlikely, but if someone loses an eye not my fault I supplied eye protection
Reply to main cut out fuse in the UK Electrical Forum area at ElectriciansForums.net
DNO ripped out antique main incomer/breaker .The guy hated us and himself and everyone else by the end of the job ! . Client going to contact...
I live in a flat in Scotland supplied with an old 2 meter system called THTC where one meter using a time signal supplied heating and hot water...
We had a new supply installed this week. DNO installed new cut out and fuse externally. Meter operator sent his engineer to move the meter in the...
Hi All, I have a client who is developing a plot of land for a single house. Currently, their 100 amp service cut-out is in a cubicle fed by...
Hi, I have a flat in a rather old building in London. Its subdivided into a few individual flats, and there is a meter board with a gas and...
