Guest viewing is limited
HappyHippyDad
Supporter
Went to see a lady to quote for removing some sockets/lights before the builders knock down a few walls. Just like to check everything.. earthing/bonding etc and noticed that the meter was still running slowly after I switched the CU off?
Slightly off subject but Its a house in the middle of a built up area with TT, why would it have TT and not TN-C-S?
Just a few odd points!!!!
There is still alot of TT systems running along old terraced houses on the external wall at high level but they are slowly been converted to TNCS
now..
you know its all about the senses in these situations dont you...
so, can you smell summat?=sense of smell
can you hear extractors goin?=sense of hearing
and if it is a grow then for christs sake dont rely on the sense of touch will you....not at some `enterprises` iv witnessed...
is another CU run from it via henleys?
That was my first thought but I cant see anything obvious, I'll try and put up a picture later.
Thanks Darkwood, thats good to know.
now..
Well you've made me smile Glen :smile5:..... got no idea what you're talking about
though :yesnod:
This reminds me of when I encountered a property with a separate underdwelling at the back. For thirty odd years they'd been paying for someone elses lighting and upstairs sockets!
You look to break through the incoming water main too, keep the ground moist, guaranteed a stable low reading.
Contrary to popular belief I did it properly mate. Dug down about a metre to make sure I wasn't going to hit anything then I started driving the rods, three rods later I decided I'd had enough.
Your medal from E54 is winging its way to you all the way from China as we speak. ;)
Not in Cornwall. Western Power are refusing to convert overhead supplies to TNCS if not already converted/connected.
I know ENG54 will be along shortly to question this, so I'm about to fire up the scanner and scan last letter from WP to confirm.
I did a job last year in Devon, with the main switch off (No other loads connected via henleys etc), the meter ran backwards for about ten minutes afterward. Only slowly, but backward all the same!!!
utter rubbish, if its disconeccted on the outgoing how the hell can it still be reading supply
Hate to drag things back to the original subject.
HHD with everything isolated did you use you’re clamp meter on the live tails? Don’t go on the neutral as that doesn’t register in the meter.
Tell me what you find.
Just to add, printed on the meter there will be a ratio, 1KWHr = --- rotations. Time the rotation and work out the inconsistency. But only if all the load is truly isolated.
HappyHippyDad
Supporter
Gloucestershire
meter still runs after power off!!
HappyHippyDad,
Knobhead,
