J
Jimmyb
As the title states : can you have two separate circuits in one box junction box ?
But the question is, "can you?" Not "would you?"
A former supervisor of mine once told us not to wire two seperate lighting circuits into a multi gang switch, as there was the potential for 400v there.
Fine, but it was a single phase installation! he was adamant in what he was saying was right !!!
That old wives tale again, a label on the switch sorts that out providing of course the switch is sufficient as in a barrier between phases, I must admit I do not care for 3 phases in switches either.
Nothing wrong with that.
Technically only label complying with 514.11.1 is needed but most people follow good practice and fit a 400v label ( although it is not required )
You can have 10 if you want.As the title states : can you have two separate circuits in one box junction box ?
Which regulation does it not comply with?For the sake of a quid?
- - - Updated - - -
If it's a EICR I would code 3 it!
Mike, Tug the cables really really hard and take up the slackwell lets put it this way----------how would you extend the circuits to a distribution board if it needed to be moved 2 ft away from it's current position and none of the existing cabling would reach?
