J
Jimmyb
As the title states : can you have two separate circuits in one box junction box ?
For the sake of a quid?
- - - Updated - - -
If it's a EICR I would code 3 it![/QUOTE
Its an outside junction box with the shower cable in twin and earth coming out and jointed to swa then the garage cable in twin and earth going into swa
well lets put it this way----------how would you extend the circuits to a distribution board if it needed to be moved 2 ft away from it's current position and none of the existing cabling would reach?As the title states : can you have two separate circuits in one box junction box ?
That's different IMHO 2 ft away is very different to being remote from the CUwell lets put it this way----------how would you extend the circuits to a distribution board if it needed to be moved 2 ft away from it's current position and none of the existing cabling would reach?
That old wives tale again, a label on the switch sorts that out providing of course the switch is sufficient as in a barrier between phases, I must admit I do not care for 3 phases in switches either.A former supervisor of mine once told us not to wire two seperate lighting circuits into a multi gang switch, as there was the potential for 400v there.
Fine, but it was a single phase installation! he was adamant in what he was saying was right !!!
no its just single phase. could spilt them into two boxes but pointless if the regs allow it first.
Nothing wrong with it at all IMO, Labels should be used though In my view.But the question is, "can you?" Not "would you?"
Beat me too it hahaI would put a label in there to warn that its 2 different circuits.
Nothing wrong with that.
Technically only label complying with 514.11.1 is needed but most people follow good practice and fit a 400v label ( although it is not required )
You can have 10 if you want.As the title states : can you have two separate circuits in one box junction box ?
Which regulation does it not comply with?For the sake of a quid?
- - - Updated - - -
Mike, Tug the cables really really hard and take up the slackwell lets put it this way----------how would you extend the circuits to a distribution board if it needed to be moved 2 ft away from it's current position and none of the existing cabling would reach?
Of course you can have multiple circuits in 1 enclosure.
It's barmy if anybody argues differently.
