Currently reading:
Testing builders work
Discuss Testing builders work in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
M
Markeboy1000
I was asked to sign off a builders electrical work, it was just a couple of spurs off of ring for rads/ underfloor heating. I just did minor works but when you sign it your signing to say you carried out works should I have done a full EIC ?
I've just dragged this from the latest edition of part P
  • An installer who is not a registered competent person may use a registered third party to certifynotifiable electrical installation work as an alternative to using a building control body.
Yup, but the schemes, who "control" the registered members haven't agreed a process as yet.
I hope you told them to get stuffed, you may as well jump out of a plane with no shute.
[Q TE=MDJ;863321]I hope you told them to get stuffed, you may as well jump out of a plane with no parachute.[/QUOTE]
What's a shute?:wink:
"Full EIC" just as non-compliant as MWC because YOU haven't designed or installed. Until 3rd party sign off process sorted out by schemes, I can only think an EICR limited to that circuit as acceptable. Bit unorthodox perhaps but if client make that the purpose of EICR then at least its clear you didn't install & what you have tested/inspected. Include intake & bonding inspection as well of course
Best you can do in this situation is carry out an EICR limited to that part of that circuit.
In that way, you are certifying that the circuit tests out ok, but crucially, you are only signing off the visible work.
The new part pee 'registered third party' option also stipulates that an EICR be issued, not an EIC.
You can do it with napit, (Its in there FAQ somewhere) You just put your name down for testing and inspection, and list there name as construction, along side a note in the comment box.
Isn't that just the standard multiple signature electrical installation certificate which is signed by the individuals responsible for design, construction and inspection/testing. To be used if different persons within the same company were responsible for those different stages and were competent in those areas?
Are Napit and others suggesting that, say, DIYers can sign these for the design and/or construction stages? Not sure I'm comfortable with that.
It is for same members of a company OR possibly a qualified sub contractor.
no , its not.
most design work on large commercial projects is carried out by independant consultants whom are completely seperate entities from the installing contractor.
Thanks for your inputs everyone. Oh and murdoch quite a lot of constructive response ideas and views on this subject but according you not a great first post obviously you know it all!
builders build, plumbers plumb (generally spelt BOTCH), plasterers make a mess..... sparks spark. end of.
The only difference between us all is, If we worked along side a Carpenter, within 3 months we could hang a door and fit skirting boards, work along side a plumber, within 3 months fit a central heating system, work along side a Bricklayer within 3 months be able to build a wall, if they worked along side us it would take them years to learn our trade.
too true, but they think they know it all. ony 3 wires, innit. BANG!
You've listed 1 element of each of those trades' work.
It's like saying electricians only install Ring Mains.
Well....... I am well aware, as are the majority on here, that signing off EIC's and notifying a 3rd parties work is a no, no.
Reply to Testing builders work in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
