Discuss 16A Fused Connection Unit in the UK Electrical Forum area at ElectriciansForums.net
Should be all right on a commercial job , domestic though its another thing unless it was on the back wall in a cupboard ,Often thought about it , because a couple of new build estates I have come across have garage supplies spurred of rings in SWA , Tight builders to blame usually , 16AMCB with double pole switch , would do it
Hi,
General question here... does anyone know of any particular reason that there's no such thing as a 16A FCU.
Reminds me of where I work got a design to install sockets which where supplied via a 16A FCU asked why he replied thats what I want so I asked who made them as they only came in 13A.
What made this really funny is that this bloke always introduced himself as Hello my name is F*** A***** Fellow of the IET
Caravan, a welder and various other items.
its not just commercial / industrial that have commando sockets.
But none of those need more than 13A.... the connection method is irrelevant. If you need a 16A outlet then you install a 16A outlet - FSU not required.
Besides, I've always gone by the thought that if MK don't make it then it doesn't exist..... and they don't.
Reply to 16A Fused Connection Unit in the UK Electrical Forum area at ElectriciansForums.net
Hi all, as in the picture, when connecting a 230V cable to a db like this, is there a legal requirement to install external RCD unit? Also, if the...
Situation is garden summerhouse fed by own 16A RCBO in consumer unit in garage over 4mm2 (overkill !) SWA . At summerhouse this goes to sockets...
Hi all, Thank you in advance... So I had an electrician put in some FCUs on spurs to a couple of outside lights.. this one was in readiness to...
DIY'er question: I have a singe switched fused spur above my kitchen counter, providing power to an undercounter fridge socket beneath it. The...
Hi, I'm doing my Level 3 Electrical Install course, and I'm doing distance learning so most of the work is being done by myself with no guidance...
