My compressor needs a 16a socket, my mates welder usess a 16A socket, oh and you could plug a caravan in without the need for an adaptor.
Just because they've come fitted with 16A ceeforms, doesn't necessarily mean that they actually draw 16A's, does it?
My compressor at home draws way over 13amp on start up especially when it's a cold start up.
Works fine on a 13amp plug.
We won't mention the fuse, apart from it does have one.
I think i've mentioned this before, in that 15A BS 1362 fuses have been available in many countries, (and for many years) that i've worked in. Now whether they are available, or officially recognised in the UK, is another matter. ....Still not quite 16A though...lol!!
Think some often forget, that the fuse in BS 1362 accessories is only there to protect the wiring/cords connected to the accessory, not the actual equipment itself!!...
So...if I were to find and place a BS1362 15A fuse into a standard 1362 plugtop, what would be my legal position in terms of BS7671<>EAWR ?? 411.4.5 / 6 suggest it's absolutely fine, but I think you might struggle to prove the point?!
If the appliance you are connecting (welder, whatever) draws anything like 16A then this is not something you should be connecting to a domestic RFC anyway -
16A Radial = no odd fuse sizes = all good.
Sorry you've lost me, ...what point are you talking about here??
Which is what I said in post #28
Why not? Please explain. Ok it would be ideal to be on its own circuit but nothing wrong with it.
What I mean, is that we have that old chestnut where something is permissible by regulations (as in, if a 15A BS1362 exists then it's fine to use subject to the usual conditions) but isn't a widely adopted practice in the UK, that people immediately shout "No!" I guess the limit in practical terms is that most BS1363 makes have a 'max 13A' stamped on them somewhere. If 15A is used elsewhere in the world with BS1363 outlets then that would suggest to me that it's allowable under the Standard?
In simple terms because you 'point' load the ring and create an imbalance - the same reason why we put immersion heaters on their own circuit.
OK i see what you mean now. I'm not saying that that these 15A fuses should or even need to be installed within BS 1363 accessories.... just that they are quite freely available outside of the UK where the BS1363 system has been adopted as the main, or part of the main socket outlet and FCU. I'd haven't checked the BS 1363 standard, to see if it allowable or not. I know when it was originally written, only 2 fuse ratings were officially recognised 3A and 13A, yet for years, 1A, 5A, and 10A were freely/widely available. I'm told that's all changed now, as i say i don't know!! lol!!
As for the UK BS 1363 plug top and system being capable of carrying 15A, ...no problem at all!! Just look at the USA's 16A outlets for both 120V or 240V, ..... and the waffer thin plug pins and internal contacts..
As my old grandfather of great esteem used to say of hypothetical questions, "If grandma had balls would she be grandpa?" :-)
