W
wolfboy
Hi just done pir, had a 16mm t+e submain feeding a d/b off live side of isolator had a 10mm t+e feeding another board about 6 metres away.
Do they go on same test result sheet as they have the same supply or seperate ones stating same supply?
il say diffrent sheets
when i did my testing at college the board had a garage coming off it which had a socket and lght off the garage db and we had to put that on a seperate sheet
I would say seperate sheets, as each board has to identified and the location of each one..........
Each of the DB's should go on their own seperate sheets on the same certificate indicating the source of supply at the top of the sheet as each DB has a different size supply cable and thus possibly a different Zdb reading.
Thats what i do. Some of my pir's may have 40+ boards.
2 d/boards 1 supply
wolfboy,
Richie Fox,
