Discuss 2 gang DP light switch in the UK Electrical Forum area at ElectriciansForums.net
E
Eddiesparks
Hi guys, quick one,
Anyone know where I can get a two gang double pole light switch that will go into a single box? For outside lights . Without using grid. Neutral run to switch. Search Google and fleabay and all I got was 2G sockets and two gang two way switches!
Cheers boys! And a merry Christmas one and all.
Click do them.
Buy a single gang plate with 2 plate cut-out, and 2 DP switches to fit in the plate, no bigger than a usual switch.
if case of a fault outside. it's on a RCD circuit, it's a good idea to switch both poles .
Telectrix spot on. Good to isolate N too in case of a N-E short.
I think i'll have to go grid then. Grid can get a bit expensive which is why I am not so keen, i'm being a skinflint!! But actually a 2G DP switch will prob be dearer!
Thanks lads
Reply to 2 gang DP light switch in the UK Electrical Forum area at ElectriciansForums.net
Is the following set up possible with a 3 Gang 2 Way Smart Wifi Switch set up (the black glass type touch ones) One of the 3 switches, switches...
Hi all, I am upgrading my traditional 2 gang light switch in the kitchen to a smart 2 gang dimmer switch. When I wired up the switch the switch...
