Discuss 2 Inch PVC Conduits bending in the Australia area at ElectriciansForums.net
E
eng-ali
What is the Approved way to bend PVC Conduits of size 2 inch and more for any angle?
lower than 2 Inch conduits can be bent with a spring.
yes available From Barton Manufacterur.
for the bending method, It is mentioned in some construction specifications I have that lower than 2 inch can be bent with bending spring, for 2 inch and larger to be bent with an approved method
what is this approved method?
I've never ever seen 50mm PVC pipe in all my years:confused::confused:
How would you calculate factors for that size conduit, they wont be in any books.
Seems more hassle than what it's worth, I'd just run 2 x 25mm pipes myself.:)
hi
used 50mm pvc a few weeks ago, not sure about bending it though looks way to big to bend. suppose yo can buy manufactured inspection elbows.
regards
gary
for example to pull cable 4CX16 Cu.XLPE/SWA/PVC which has approximately 25 mm dia but it will be pulled inside 2 inch conduit with a little bends cause it is armoured
I got a method but Idk wether it is approved or not:
put some sands on the 2 inch conduit after filtering it from any other impurities, afterthan it will be heated with bending it to the required angle at the same time.
I got to ask.......why would you put SWA in a plastic conduit???
Fair enough underground ducting, but conduit???
I have now a case of pulling cable underground to a building of a room with final DB has 40A TPN ISO
and this conduit has to be on the wall to pull the can be from underground duct to the DB but the problem is that I have this Structural situation ( I think it would be better If I described it in a sketch):
I have a concealed bend 90 degree already with the tie beam of the mentioned duct. block will be 20 and insulation of 5 cm and another block of 10 cm. Duct is concealed with 20 cm block and I need to bring to the 10 cm block. cause it is armored cable I don't think 90 bend is good solution, but I need only slight bend.
What for???
hi lenny
we were doing a milking parlour with with 6 different rooms, 3" trunking along the walls and used the 2" pvc adaptors an conduit to go through each wall to the other room and then carried on in 3". did think about cutting through the wall and continuing the 3" all the way but the finish on the walls were very expensive and didnt want to damage it. it worked very well.....
regards
gary
eng-ali
i have been sparkying in australia for the past 10 years since moving from scotland and we use 50mm pvc conduit alot, the easiest way to put sets into it is to get yourself a good heatgun and heat a large section of it while turning it to make sure it is plyable all the way round, dont heat it to melting point or it will kink, just make it plyable and start to set it gradualy, you will have to keep heating and bending and to keep its shape have a damp rag at hand so you can form it and not burn your fingers.
take your time as it does take practice, also form it on a flat concrete surface to save the bend from going off to one side.
hope this helps you out
Also over here we use 50mm flexible conduit for bits like that if you want to cheat..
eng-ali
But is heating accepted method for bending?
Reply to 2 Inch PVC Conduits bending in the Australia area at ElectriciansForums.net
Hi, I'm a DIY'er looking to build a 6x8 shed in my backyard in Colorado. I'm installing a gravel pad first, with 4 concrete Sonotube...
Hello, I have 50 ft of corrugated pipe buried between my house and a pool shed. I placed it where I knew future landscaping would make it very...
Hi, I'm running a 70ft underground UF cable in 3/4 inch PVC conduit to 2 sheds. The sheds are 3ft from each other. I'm just a DIYer enthusiast so...
Hi All. What is the best/preferred method when connecting 20mm conduit to a back box of a socket on an outside wall ? I am connecting a BG...
