Hi everyone
I've moved into a flat and I've decided to replace the original electric switches and sockets with white ones. I've done them all however
I'm having problems getting the last 2 switches to work correctly:
There is a double light switch in the entrance hallway of my flat, the left switch should turn on the hallway light, the right switch should turn on the stairs & landing light.
There is a double light switch at the top of the stairs which also should do the same as the downstairs switch (2 way I believe).
I took a photo of the original switch wiring before removing and thought I had wired it the same but I haven't and have balls'd it up somewhat.
What now happens is the left switch on both the upstairs & downstairs light switch turns all 3 lights on & off, the right switch on both does nothing.
Each socket has 2 x 3 core cables & 1 x 2 core cable running to it (3 in total)
I have included pictures of the wiring, hopefully they'll help.
Any help given would be greatly appreciated, and apologies for my stupidity!
Cheers
Stewart
Cheers
Stewart
