Discuss 3 Common terminals within a Fan Isolator switch in the UK Electrical Forum area at ElectriciansForums.net
DIYBlues
Hi Guys
I wonder if you can advise on a fan isolator I am installing....
On the reverse of the fan isolator I have the following markings:
Top L1 (common) L2 N (common)
Bottom L1 L2 (common) N
Originallly I was going to wire it up supply to the top terminals and fan to the bottom terminals
as seen in many other wire diragrms. However the fan Isolator I purchased as the terminals
marked as above.
Now I'm thinking I should connect the supply in all the common terminals regardless if they are at the top and bottom
and fan to the or L1, L2 and N terminals.
For clarity I have not included the blanked off L1 and L2 terminals on the rear
Any advice would be greatly appreciated.
Regards
DIYBlues
L1 - permanent live
L2 - switched live
N - neutral
Wire supply and load to this regardless of the physical layout. For a pice of mind turn the switch on, and bell the terminals out with a multi meter set on continuity before you fit it.
Reply to 3 Common terminals within a Fan Isolator switch in the UK Electrical Forum area at ElectriciansForums.net
Hi all, After a bit of diy advice….(I’m in the UK) I’m trying to replace some grid switches for the washing machine from white to steel ones...
Morning All I recently completed my first re wire and board change, (with help from the owner who is a gas fitter and plumper, who works with my...
Hi all, I did train as an electrician but never worked as one so my experience is limited and ive not done anything for a while now. I have an...
Sorry for the long first post, I wanted to be as thorough as possible. On my landing I have a 2-way switch setup, one of which is 3-gang, one of...
