Discuss 3 Phase Supply, Need A Seperate Earth in the Canada area at ElectriciansForums.net
the installation costs would be the same as you can generally get away with installing the swa and earth at the same time
that just leaves the price per metre of 25mm 5c swa versus 25mm 4c swa & 16mm earth
Thats what I ment it will cost more to run a 5-core swa than 4-core and seperate 16mm cpc
Without knowing the full facts I see that no mention has been made of making the remote supply TT. This has the advantage of not requiring a CPC. The Swa is broken on entry to the remote building and is bonded at source. RCD protection is of course required and an earth stake.
Reply to 3 Phase Supply, Need A Seperate Earth in the Canada area at ElectriciansForums.net
hi guys / girls , any advice would be appreciated, So the situation is a domestic property has a 3 phase supply , from the service head we have 3...
Hi Guys, We have a CNC router which uses single phase for the spindle, stepper motors and control box. This is all wired in and working...
Absolutely losing my brain here guys What I would like to be able to do is power our 3 phase motor on a single phase supply. Thought I had it...
I have a single phase stainless steel pasteuriser that has two control boxes attached to it. One box houses the control for the electronics and...
