- Reaction score
- 16,999
@davesparks - yes , you are right. I just confused it entirely. A short ryt after the load ( i-e positive side wire with the negative side wire will bypass the load and the fuse will blow so no current passes through load.
But a short before the load that is on negative side still will cause fires ( damages to wire ) because there is no fuse in that side ?
You can't have a short on the negative side
